Can someone please help there is 2 unused micro antenna ports in the WiFi board. If I put an antenna wire on both or one port will it increase controller range. I’m about 30cm out if range in my bedroom.
I don’t think it will help. As far as I can tell, the one port with the antenna-cable that goes to the front panel is meant for the controller connection.
The other two ports are for Wifi and are filled with some rubber stuff. These are not used as there are antennas for 2.4 / 5 GHz printed on the circuit board.
Cheers mate I’ve replaced it with a one s console.
It’s got no wire antennas and has better range
I don’t know how that is possible.
