sorry, I trying to attach picture file but I can not attach the files. An error message is appear “Sorry, you can’t embed media items in a post.” I’m not sure this msg.
Yes, I think so too. However, it was not in this case. First, I removed M92 but the short was existed. Second, I removed P13 IC but the short was existed too.
I have already checked M92 and P13 IC.
M92 and P13 IC were removed but the shorts were existed.
Yeah, if you were to have one I’d disconnect the EMMC module for the time being and then connect your PSU up to your shorted rail and supply no greater than 1.2V (in case it’s shorted elswhere) and with a current limit of 500mA to begin with and then see what if anything gets hot.
This is not always a foolproof method but there is so many things residing on this rail that it’s a bit of a pain and failing the above you have to start pulling things off the board to rule out.
Hi, Severence san, I bought PSU and supplied 1.2V & 0.5A but I don’t feel hot spot.
I don’t have thermal camera. I know if I have a thermal camera, it’s easy to find hot spot.
Increase the current in 100mA increments until you can feel te culprit getting hot. I would not recommend setting the currrent limit high straight off the bat in case you clear the short before finding the culpit.
I bought new capacitor and then replaced it. I confirmed that the shorts was gone.
However, Switch start up was failed.
Before I replaced a shorted capacitor, Switch start up was failed with black screen.( no logo, no back lights) After I replaced a shorted capacitor, Switch start up was failed after the Nintendo logo mark.
I monitored the charging voltage and current during start up.
Before turn on the switch, voltage is about 15V and current is about 0.4 amps.
5 seconds After turn on the switch, Voltage and Current are shutdown.( probably 0V and 0amps. I can not confirm it because the USB tester go turned off.)
In this case, failure is still in exist on my Switch?
This i possibly a good sign as it’s indicating your switch is trying to boot. (the drop to 0A)
I would look carefully at the M92 IC and check for any issues in regards to your soldering, It’s also entirely possible the M92 IC has failed at which point it might be worth replacing.
The BQ IC would be the next port of call if thie above does not resolve your issues.
this is the first logo right? you don’t make it to the second logo?
You could also remove the M92 IC and try booting the console with just the battery and if the M92 was the issue then HOS will startup with an error code.
